Forums >> Revit Structure >> Technical Support >> Custom Beam System Tag
Wed, Dec 9, 2009 at 1:10:49 PM | Custom Beam System Tag
BigD
BigD Avatar
1 Stars: 1 Votes
I've searched the forum and the web and have drawn a blank thus far.
I create beam systems using the "Maximum Spacing" Layout rule.  For example, I've created a Beam System of Bar Joists that are spaced at 2'-6" maximum spacing.  So, it turns out that the ACTUAL spacing is like 2'-5 1/16".  When I used the out of the box beam system tag, it says
18K6 @ 2'-5 1/16"
I want the tag to read
18K6 @ 2'-6" MAX.
How do I make that happen?  Is it possible?  I've tried using a Shared Parameter but . . . no luck.
Wed, Dec 9, 2009 at 1:58:56 PM | Custom Beam System Tag
TKennedy
4 Stars: 8 Votes
I'm not sure this will work for you, but it's something to try. In the tag family edit the Centerline Spacing label. Click the parameter units button, uncheck "use project settings", and change the rounding to 1". Add "MAX" to the Suffix.
Wed, Dec 9, 2009 at 3:56:18 PM | Custom Beam System Tag
BigD
BigD Avatar
1 Stars: 1 Votes
Pretty good trick!  I think that might just work!
Thanks!
Wed, Jun 5, 2013 at 6:03:46 PM | Custom Beam System Tag
djohnson1
This doesn't always work. Your spacing sometimes ends up that it will round down instead of up. Has anyone found how to put the maximum spacing parameter in instead of the centerline spacing?
Beam System Tag
Fri, Aug 14, 2009 at 3:09:33 AM
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:43 PM
Automatic Beam System and Tag On Options
Wed, Nov 26, 2014 at 7:29:00 PM
Tag Beam System In section/elevation
Wed, Jul 5, 2006 at 3:56:43 PM
Beam System Tag
Mon, Feb 23, 2015 at 2:19:47 PM
Page generation time: 0.3367
