Forums >> Revit Structure >> Technical Support >> Soffit Plan/Bottom of Deck Plan
Tue, Dec 8, 2009 at 11:38:11 AM | Soffit Plan/Bottom of Deck Plan
krunung
I'm trying to create a plan view that shows only the botom of a concrete deck, i.e. downturned beams, columns, bottom of slab steps. I'm fairly new to Revit and this may be a silly question but is there any way to show only the bottom of a deck in a plan? I suppose I could set the view elevation to be in the middle of the slab but some slab steps may be bigger than that creating a partial top of slab view along with it. Plus with a parking garage/car park, the ramps would be cut by the plane as well. Hopefully htis makes sense... Any thoughts? Thanks
Kris Runung
Project Manager/Engineer
McClone Construction Co
Wheat Ridge, CO 80033
Spot Elevations In Plan
Mon, Aug 7, 2006 at 5:14:23 PM
Gypsum ceiling with vertical walls to create soffit?
Thu, Dec 18, 2008 at 9:34:06 AM
1 1/2" Metal Deck Visibility
Tue, May 13, 2008 at 11:40:33 PM
Metal Deck Diaphram
Thu, Jan 4, 2007 at 11:27:05 AM
wrap bottom of soffit wall
Mon, Aug 18, 2008 at 4:30:20 PM
Page generation time: 1.1024
