Forums >> Revit Building >> Technical Support >> Image off by just a pixel - can't compile.
Tue, Dec 8, 2009 at 10:22:35 AM | Image off by just a pixel - can't compile.
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Hello... I rendered a series of jpeg images (2200 frames). My output setting dimension was 900 x 675 (default), the problem i'm having right now is that some of the images came out in 894 x 671 and 894 x 670 (not even close to 900 x 675 - I have no idea why it came out that size). Anyways, I'm just trying to salvage the 2200 frames that's already been completed... my problem is that I CANNOT compile this series of images because some of the images are OFF by a just a PIXEL. I used VitualDub btw to compile it. So my question really is.... what would be the easiest way to modify the IMAGES of "894 x 671" to 894 x 670? so i can compile it using VirtualDub.
Note: I tried the "filter" in virtualdub and added the "resize" and then crop it.... but this seem to be a lot of work and don't seem to work. Any help would be appreciated.
 Thanks!
 "If you tell the truth, you don't have to remember anything"
Tue, Dec 8, 2009 at 11:22:26 AM | Image off by just a pixel - can't compile.
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
I guess I meant to say... It's off by a one pixel "line". If that even make sense.
Wed, Dec 9, 2009 at 4:09:25 PM | Image off by just a pixel - can't compile.
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Does anybody have any answer for this? Thank you!
.xls spreadsheets or generic tables?
Wed, May 10, 2006 at 2:20:45 PM
Attatching an image to a 'Model in Place' mass
Fri, Apr 27, 2012 at 9:36:34 AM
Disillusionedwith Revit
Tue, Aug 22, 2006 at 6:57:21 PM
Unwanted printing lines
Mon, Nov 5, 2012 at 12:10:46 PM
Avatar
Sat, Sep 10, 2011 at 4:57:54 AM
Page generation time: 1.8332
