13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Creating column families from scratch
2 Posts No Rating |
Hi All, I am relatively new to Revit and would like to learn to create my own structural columns. Can someone point me in the right direction as far as setting constraints using reference lines and linear dimensions to control model geometry? I have no formal training in Revit, but have used several cad packages over the years. Cheers, Raoul
As a general rule a good methodology is: - Plan what you want,
- Add required reference planes,
- Add required parameters to reference planes,
- Flex to ensure it behaves as expect - repair if necessary,
- Then add geometry and constrain to reference planes,
- Add any further material or visibility parameters to the geometry,
- Flex,
- Create New Type,
- Save Family
Start with the inbuilt family creation tutorials, but columns are some of the easier families to create. Just don't constrain the levels...
Regards,
Chris.
Inexperienced in creating families from scratch in Revit 2008... Help please??? |
Sun, May 2, 2010 at 5:00:11 AM
Creating Waal from scratch |
Tue, Dec 20, 2005 at 12:35:28 PM
creating tables from scratch |
Fri, Mar 27, 2009 at 11:41:06 AM
Creating a .pat from scratch |
Mon, Jun 1, 2009 at 8:03:57 AM
Using a C-Channel as a column |
Wed, Jun 14, 2006 at 4:45:09 PM
