Forums >> Revit Building >> Technical Support >> Curved railing
Mon, Dec 7, 2009 at 5:36:57 PM | Curved railing
wil9000
Hi,
I am trying to create a curved rail to span about 50 meters over a bridge, can anybody offer any suggestions as how to do this, ideally i want it to curve following the outer edge of a circle (part of) and say at an angle when looking at it  through section of 70 degrees - is this too much wishful thinkking for revit 2009?
Many thanks
Will
Mon, Dec 7, 2009 at 9:31:17 PM | Curved railing
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
By the sounds of it you would need to create it in-place if its what i think it is.
Create a Reference Plane at your 70degree angle as the work plane and setup a section parallel to this.  Then create a sweep along this work plane to the desired curve and set the profile appropriately.
HTH.
Regards,
Chris.
Curved railing.
Fri, Nov 15, 2019 at 11:36:39 AM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
Railing on curved/sloped wall
Wed, Nov 21, 2018 at 12:06:53 AM
13
Double curved railing
Fri, Mar 2, 2007 at 7:58:14 PM
gate/railing query
Wed, Sep 7, 2011 at 7:04:57 AM
Page generation time: 1.0397
