27 Users Online (25 Members):
Forums >> Revit Structure >> Technical Support >> Stationing Grids and Dimensions REVIT Structure 2010
4 Posts No Rating |
Has anyone ever tried to use stationing labels for grids and dimensioning in REVIT Structure 2010? I was hoping to create a parametric relationship between a stationing label and the shared coordinate system within the project. Does anyone have any idea of how to accomplish this? By stationing for example: 6X+500, 7X+000, 7X+500, 8X+000 etc... The project is set up with a shared coordinate using state plane coordinates. (Northing = some number and Easting = some number). I want to relate one station point (1X+000) to that shared coordinate point such that when I dimension to any point or structure it will show as a stationing point (6X+232) as oppose to a length in meters. My initial thought was to create a family that takes a dimension length from a reference plane and labels it as a station buy using a formula in the type parameters, however I am not quite sure how to write the formula to accomplish this. Thank you for any help/advice.Lisette Terry
----------------------------------- Life is not always linear... |
Moving a Portion of a Building |
Wed, Dec 14, 2011 at 10:49:57 AM
Dimensioning grids |
Thu, Sep 21, 2006 at 9:50:34 AM
DIMENSIONing GRIDS - on plan view |
Thu, May 26, 2011 at 1:33:19 PM
grids in 3D view |
Fri, Dec 17, 2010 at 11:08:31 AM
Tag dimensions to reference plane in 2010 |
Wed, Jan 6, 2010 at 1:41:42 PM
