Forums >> Revit Building >> Technical Support >> Revit 2010 - Shadows from floor plans on mass
Sun, Dec 6, 2009 at 12:08:27 PM | Revit 2010 - Shadows from floor plans on mass
susiearch
I’m rendering a 3d plan view (orientated to view). I’ve created a mass at each floor. When I turn the shadows on, shadows from the exterior walls are cast onto these masses. However, when I render they are not. Is there a way to render these shadows?
 Thank you
Mon, Dec 7, 2009 at 5:14:35 PM | Revit 2010 - Shadows from floor plans on mass
eldados
eldados Avatar
4.5 Stars: 8 Votes
if you have shadows in shaded, you should see them in rendered view. are you using "use shaded view settings" for rendering?
also, in rendering settings, bring the sun intensity a little down and make shadows a little darker...
does this help?
Integrator
KarelCAD
Tue, Dec 8, 2009 at 9:16:24 AM | Revit 2010 - Shadows from floor plans on mass
susiearch
Could you please expand on where to find "use shaded view settings". Also not quite related but there's a lot of discussion in the forums about using "mental ray" do you know how to this verify I'm using this?
Thanks
Wed, Dec 16, 2009 at 10:51:19 PM | Revit 2010 - Shadows from floor plans on mass
susiearch
I'm sorry I didn't reply sooner. This did help.
Thank you
Thu, Dec 17, 2009 at 3:04:32 AM | Revit 2010 - Shadows from floor plans on mass
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Give the mass a material other than the default and ensure masses are turned on in the view and you haven't just got the "show mass" global option to show them.
Metal Ray is built into Revit 2009 onwards.
Regards,
Chris.
Shadows on floor plans
Sat, May 18, 2013 at 7:41:40 PM
Rendering problem with soft shadows on Revit Arch 2010
Wed, Jan 20, 2010 at 5:58:33 PM
Sun and shadows in 1st floor
Wed, Jan 31, 2018 at 11:13:23 AM
Revit shadows in rendering
Thu, Jan 14, 2010 at 12:14:48 PM
V7 Shadows
Wed, Dec 8, 2004 at 5:41:46 PM
Page generation time: 3.6450
