Forums >> Revit Building >> Technical Support >> Edit Sketch up file
Sat, Dec 5, 2009 at 9:56:26 AM | Edit Sketch up file
susiearch
I’m trying to change the materials of a linked Sketch Up file, in Revit 2010. I’ve gone through the Manage > Settings > Object styles and adjusted the materials from there, but nothing, its still rendering as white.
Thank you
Edited on: Sat, Dec 5, 2009 at 9:59:57 AMEdited on: Sat, Dec 5, 2009 at 10:04:06 AM
Edited on: Sat, Dec 5, 2009 at 10:07:24 AM
Sat, Dec 5, 2009 at 10:43:20 AM | Edit Sketch up file
4 Stars: 205 Votes
There are lots of threads like that here in the forum, try to search them in "Search" button with "Sketchup word....
Sat, Dec 5, 2009 at 11:05:38 AM | Edit Sketch up file
susiearch
I have looked though hundreds of threads. There of 1450 with sketch up in the title, and since the titles are all pretty much the same it’s difficult to find what I’m looking for. I found one at http://www.revitcity.com/forums.php?action=viewthread&thread_id=14101#t49400 that stated the exact problem I’m having but the video with the solution is nowhere to be found.
Thank you
Sat, Dec 5, 2009 at 12:10:26 PM | Edit Sketch up file
4 Stars: 205 Votes
I remember that thread but if you look at the end of that thread you will see another LINK to Megaupload, download that link and see the video, it's a similar video not for that guy but i think you gonna understand.
Sometimes i must delete some videos in the Screencast because i don't have enough space to put another videos, also, in that thread look what "Erland" said....
Sat, Dec 5, 2009 at 12:19:49 PM | Edit Sketch up file
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Also check what this guy posted a couple of months ago, could be useful for ya......
http://www.revitcity.com/forums.php?action=viewthread&thread_id=18203&start=15
Sat, Dec 5, 2009 at 7:38:09 PM | Edit Sketch up file
susiearch
I found the first tutorial mentioned above very helpful, I didn’t try the second. I also found very simple, straight to the point explanation in the thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=18203&start=15
Thank you for your help
Sun, Dec 6, 2009 at 5:22:06 PM | Edit Sketch up file
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
here is also a video rkitect made on how to do it.
http://gibsonhh.info/revit/video/sketchupRendermaterial.swf
J. Allen Ball
Revit won't (Grey/Halftone/Fade) during any Sketch/Edit/Modify mode
Tue, Feb 27, 2018 at 11:18:53 AM
Stairs Disappear upon edit sketch mode.
Wed, Jun 6, 2018 at 12:49:18 PM
Question about sketch Mode
Thu, Jan 17, 2013 at 6:34:56 PM
Help - Sketch Up Models are hidden!?
Tue, Dec 7, 2010 at 10:35:46 AM
How to edit a sketch of Extrusion?
Thu, Aug 1, 2013 at 10:38:11 AM
Page generation time: 0.6741
