Forums >> Revit Building >> Technical Support >> editing linked files without having them unlinked?
Fri, Dec 4, 2009 at 5:38:46 AM | editing linked files without having them unlinked?
madvit
Hello,
 I'm working on a site plan and on various buildungs , separate files, linked into that siteplan. I want to work on both files, having both files open, switching between them, but it seems not possible, Revit 2009 always tells me it has to unlink the file first. I thought using Worksets is the way to do it but that did'nt help me. i also don't understand it completely i must admit.
any help?
thanks
Fri, Dec 4, 2009 at 9:56:29 AM | editing linked files without having them unlinked?
TKennedy
4 Stars: 8 Votes
You cannot have a linked file open while you still have the project it is linked into open in the same instance of Revit (I don't know why). The workaround is to simply start Revit again and have two copies running on your machine (not sure if this uses two licenses) and open the linked file in the second instance of Revit.
Fri, Dec 4, 2009 at 10:06:44 AM | editing linked files without having them unlinked?
madvit
thanks! only my machine is having trouble dealing with ONE instance of revit open, don't think it can handle two. need a new computer. But should work, thanks! a edit-in-place-button would be nicer, though!
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Linked Files Revit 2009
Wed, Aug 31, 2011 at 3:27:11 PM
linked files - material override?
Mon, Aug 31, 2009 at 9:59:52 AM
Managing linked autocad files
Thu, Dec 3, 2009 at 9:19:42 AM
Page generation time: 0.2759
