Forums >> Revit Building >> Technical Support >> Relative Levels to Topography
Thu, Dec 3, 2009 at 11:20:29 AM | Relative Levels to Topography
CraigEngland
Hi,
 I have just created a toposurface that has an elevation around 300m above sea level.
How do I make my levels relative to the topography?
For example...let's say Level 1 is 300m and Level 2 is at 305m.
I want the Level 1 to read 0m and Level 2 to read as 5m.
Thanks!
Thu, Dec 3, 2009 at 11:52:24 AM | Relative Levels to Topography
cheryla
3 Stars: 2 Votes
You will have to either drop the topo down to 0 and label it as 300, or keep the levels at 305, etc...
Any other suggestions?
Cheryl Nelson
Randall W. Hein Architects
Thu, Dec 3, 2009 at 12:39:49 PM | Relative Levels to Topography
coreed
coreed Avatar
4 Stars: 16 Votes
you should be able to find plenty of info on how to do this already posted on this site.
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Dec 3, 2009 at 1:09:28 PM | Relative Levels to Topography
CraigEngland
Yes, there is plenty of info on how to move the levels. But I cannot find any information on how to make my level 1 at 300m be read as the 0m line. Can this even be done? or will the level always display the actual elevation...
Thu, Dec 3, 2009 at 1:24:02 PM | Relative Levels to Topography
tim123
4 Stars: 19 Votes
If you go into the properties of a level marker Elevation base can be set to project or shared.  Set it to project.
Thu, Dec 3, 2009 at 1:31:35 PM | Relative Levels to Topography
CraigEngland
Ok! Thanks! I now understand how its working. What's a bit bothersome is that my topography moves when I set the project location....but i guess it;s just the order of how i set this up...
Creating levels below topography/raising topography?
Fri, Apr 12, 2013 at 1:22:50 PM
Relative Levels and AHD
Wed, Oct 26, 2005 at 1:00:26 AM
Relative Revit Levels.
Mon, Sep 15, 2014 at 9:58:19 PM
Relative levels
Mon, Dec 14, 2009 at 2:29:26 PM
Spot Elevation Relative to Floor
Wed, Jun 5, 2013 at 6:53:59 AM
Page generation time: 1.9849
