19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> I can't see my Elevation View
1 Posts No Rating |
Sorry if this is in the wrong forum, I wasn't sure where to put this in... Self-explanatory, I can't see my elevation views. This isn't the first time that this has happened to me, but it's getting more and more annoying and...just plain bothersome. When I first open up a new project it's there, but after working a bit and when I realize I need to add another elevation level, the elevation views aren't there, I can't find it in the browser bar in the side and etc. What's more, if I copy my design to a new project sheet, I get my elevation views, but then my 3D view disappears. A little help? Anyway to bring my missing views back or am I doing something funky? Thanks.
If the elevations aren't showing in the browser then they must have been deleted, although Revit warns you before deleting an elevation. If you go to a plan view look at the elevation marker (if you can't see it then unclick crop view or click on the bulb to reveal hidden elements). The elevation marker has a box on each side. The checked ones indicate where views are associated with it, so check one if they're all unchecked. Click on the arrow to show the extents of the view, as the view may be cropping before your actual building. You can get a new 3D view at any time by clicking on Default 3d view.
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW |
Mon, Jul 29, 2013 at 4:50:17 PM
Structural beam won't show in elevation |
Fri, Aug 12, 2005 at 5:22:08 PM
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:39 PM
Interior Elevation Tag |
Wed, Dec 19, 2012 at 2:25:25 PM
can't see elevation tags in one view |
Tue, Aug 30, 2016 at 1:34:14 PM
