Forums >> Revit Systems >> Technical Support >> Family types - conditional statement
Thu, Dec 3, 2009 at 9:56:56 AM | Family types - conditional statement
Rams
3 Stars: 3 Votes
Hi all,
Its me again with family query...
I have a family with five types. Now i have a shared parameter for PART CODE.
I can separately put data in VALUE field for all types but if i create a formula then the same formula is shown in all types. Can we have different formula for different types?
Thanks
Rams
Now on the implementation stage....
Fri, Dec 11, 2009 at 3:38:55 PM | Family types - conditional statement
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
you can if there is already a different driving factor in each type, ie. nominal pipe size or something along those lines
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Fri, Dec 11, 2009 at 3:43:48 PM | Family types - conditional statement
TomDorner
4.5 Stars: 25 Votes
Sounds to me like you are over complicating the situation.  Five types is not that many and if the part code remains constant for each type then I would simply do the data entry and be done with it.  A general rule of thumb that I use for creating families though is to use "type catalogs" where there is anything more than a single type.  Then I can use Excel or a text editor to shortcut the data entry work and limit the overhead of loading mulitple types into the Revit project when I only need one or two.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Mon, Apr 18, 2011 at 2:34:32 PM | Family types - conditional statement
Purtle
I have a family for a receptacle that has two types.  One is for a standard receptacle, the other for an above counter that shows a slightly different symbol.  Both family types have two seperate elevations.  When placing them on floor plans using either type, they come in at the correct elevation.  If one is placed and i swtich to the other type, everything changes correctly except the elevation.  Can anyone tell me if i could be setting something up incorrectly?
thanks ahead of time.
Mon, Apr 18, 2011 at 3:59:50 PM | Family types - conditional statement
thetabest
thetabest Avatar
3 Stars: 2 Votes
when you place your instance of one receptacle, it is inserted at its default elevation...  When you change it to the other type, it remains at that elevation, because the default value is ONLY applied when innitially placed.  I recommend selecting all instances in project/view of the given type (counter top lets say) and then setting all of those to the desired elevation.  Repeat for the non counter and you are done.
GL
Trent Best
Best Systems
the.tabest@gmail.com
Conditional statement
Thu, Jun 27, 2013 at 9:58:47 AM
Conditional Statement
Fri, Dec 4, 2009 at 9:49:42 AM
if yes/no statement controlled by if yes/no statement
Tue, Jan 22, 2013 at 4:08:26 PM
Minimum / Maximum Parameters
Fri, Nov 3, 2006 at 2:04:26 PM
Dimension parameter based on visibility
Tue, Sep 22, 2009 at 3:42:59 PM
Page generation time: 2.5007
