Forums >> Revit Building >> Technical Support >> Imported setting won't show itself (2010)
Wed, Dec 2, 2009 at 9:23:37 PM | Imported setting won't show itself (2010)
ZSPTurbo
I imported a setting model from sketchup, saved it as a project, and then linked that project into my current project. when I import it, it showed me the message I have attached an image of.
The linked file is not visible, but it appears when I click the lightbulb.
When I press "vv" then click the "revit links" tab at the right, and click the "by host view" button under the "display settings" column", I get the second attached image.
If anyone can help, it would be greatly appreciated.
Hatch Pattern in GYP ceiling won't show
Thu, Mar 12, 2009 at 10:00:42 AM
14
Imported Component won't show up in plan view.
Thu, Aug 30, 2012 at 12:49:26 PM
Wall won't show in North elevation
Thu, Oct 9, 2014 at 12:21:15 PM
Elevation won't show in preview and can't be printed out
Fri, Nov 20, 2015 at 10:58:59 AM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Page generation time: 0.9133
