Forums >> Revit Building >> Technical Support >> Edit Cut Profile
Tue, Aug 30, 2005 at 4:43:27 PM | Edit Cut Profile
Rugrat
When I edit the cut profile the new extended profile appears as a thick line. Is there a way to control this line weight? Post edited on 2005-08-30 19:03:23
Tue, Aug 30, 2005 at 5:55:32 PM | RE: Edit Cut Profile
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If edit cut line styles is disabled it will use the Walls project line type in object styles. If enabled it will use the override set for that particular layer of the wall. HTH.
Tue, Aug 30, 2005 at 7:03:10 PM | RE: Edit Cut Profile
Rugrat
How do I disable or enable this. I don't see it in the line styles. Am I looking in the wrong place?
Tue, Aug 30, 2005 at 7:22:39 PM | RE: Edit Cut Profile
Rugrat
Never mind I found it in the VG Window. TFYH
Tue, Dec 20, 2011 at 6:00:24 AM | Edit Cut Profile
SJark
This will clean up cut profile lines, but takes away thick outline of the exterior layer of all the walls in view as well. The tool has some wrong logical conections. These lines needs to be threated separately.
Any better solution in Revit 2011? It's really annoying in all my details.
Edited on: Tue, Dec 20, 2011 at 6:11:22 AM
Edited on: Tue, Dec 20, 2011 at 6:17:26 AM
big problem with edit cut profile????
Sun, Sep 11, 2005 at 9:38:48 AM
edit cut profile
Mon, Aug 2, 2010 at 1:18:58 PM
Edit cut profile line thickness
Wed, Nov 18, 2009 at 12:15:27 PM
metal deck cut profile
Thu, Nov 4, 2010 at 9:17:43 AM
Edit Cut Profile
Thu, May 26, 2005 at 11:08:43 AM
Page generation time: 0.4077
