Forums >> Revit Building >> Technical Support >> Stacked wall layer editing
Tue, Dec 1, 2009 at 9:03:54 PM | Stacked wall layer editing
vshum
Revit 2010-Does anyone know how to edit the layers of a stacked wall so that you can control the interior layers to separate them around floors?  I've attached a PDF of the problem to show what I'm talking about.  I want to adjust the metal studs and gyp board in the attached wall to stop just above the first floor ceiling and start again above the second floor.  I'll appreciate any ideas.  Thanks.
Wed, Dec 2, 2009 at 7:01:24 AM | Stacked wall layer editing
You will not be ablt to do this with stacked walls.  You could break them up then if your layers are unlocked, you can adjust those.
Wall layer thickness turned "variable"
Wed, Aug 21, 2013 at 3:25:34 PM
Stacked Walls - Can't select wall layers
Mon, Jun 24, 2013 at 3:14:41 PM
stacked wall line visable on the wrong side?
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Exporting and layer modifiers
Wed, Nov 16, 2011 at 4:04:33 PM
Page generation time: 0.5806
