Forums >> Revit Structure >> Tips & Tricks >> Wall Display in Plan
Tue, Dec 1, 2009 at 3:17:45 PM | Wall Display in Plan
BigD
BigD Avatar
1 Stars: 1 Votes
Doubt I'm the first person to ask this, but I couldn't find . . . the answer that I want . . . in a quick search.
 Can I control the display of compound wall components in various views?  Specifically, here's what I WANT:
ICF Wall (Insulated Concrete Form) . . . I've modeled the Concrete CORE, and then I've placed Rigid Insulation on each side of the CORE.  In Plan View, I want the display level to be COURSE, and I only want to see the Concrete CORE.  I don't want the Rigid Insulation to show.  However, in Section Views, I would like for the Rigid Insulation to display.
HOW?
Wed, Jan 13, 2010 at 12:30:59 PM | Wall Display in Plan
ChandejL
5 Stars: 2 Votes
You can use graphic over-ride for each view to any wall cut pattern you want.
How do you control the display of wall layers in the Roof Plan?
Fri, Jul 20, 2012 at 10:51:46 AM
problems with wall display.
Tue, Jan 12, 2010 at 10:29:13 AM
Display issues in roof plan
Mon, Feb 16, 2009 at 10:06:45 PM
Wall display issue
Tue, Jul 6, 2010 at 5:00:14 PM
How do I get my walls in plan view to display as an assembly? Revit 2015
Mon, Mar 2, 2015 at 1:02:34 PM
Page generation time: 1.0962
