Forums >> Revit Structure >> Technical Support >> printing - .prn displays with black background
Tue, Aug 30, 2005 at 1:48:35 PM | printing - .prn displays with black background
JAMIER
Revit Structure 2 on winxp. I am trying to set a plottter to print through revit. We currenly have and ocdtds400 and tds600 in house. When print from acad we print to file and process the plot file through repodesk software when sending to the plotter. I have currently set up a local printer at the client. I have use driver HP Design/jet 750C (E/AO) Color per a pdf document from "PacBlue Digital" called "Plotting from Revit". It seemed to make sense. My problem is when viewing the .prn in reprodesk parts of the drawings are displayer with white background which is ledgible and other parts are with black background with ghost images of the geometry below it. Any idea what is causing this or a better solution for setting up a plotter. thanks, jamie
Tue, Aug 30, 2005 at 4:39:54 PM | RE: printing - .prn displays with black background
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds like the drawing is not fitting on the sheet? Check you are plotting with the appropriate sheet size for the view...
PRN plot files
Sat, Apr 9, 2005 at 1:40:49 AM
Decal Background is Black
Wed, May 1, 2019 at 5:57:17 AM
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:56 PM
revit 2012 - display option background disappeared and turned black
Mon, Jun 25, 2012 at 4:48:13 PM
Black background in text box
Fri, Feb 19, 2016 at 7:23:02 AM
Page generation time: 1.2518
