Forums >> Revit Building >> Technical Support >> Rendering wont do second cycle - revit arch 2010
Mon, Nov 30, 2009 at 1:40:44 PM | Rendering wont do second cycle - revit arch 2010
ZSPTurbo
I'm rendering a project, using region instead of just screen, on "High" or "Best", with the printer setting of 150 or 300 dpi, resulting in an image about 3000x3000 pixels. Sunlight only, from "top left" or "top right"
I have two different problems that reoccur and go away seemingly at random.
Sometimes when I click "render" it gets to work just like usual... but it never changes the image from the original model image. No little rendering squares of triangles, just the original model.
The bigger problem is that sometimes it will render like normal, but it wont do the second "cycle" of rendering. It just does the first rough render, and then finishes. WHAT THE curse?!?!?
Someone please help me. PLEASE!!
Mon, Nov 30, 2009 at 1:46:29 PM | Rendering wont do second cycle - revit arch 2010
4 Stars: 205 Votes
Did you install the Web Updates to Revit?
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12828862
Mon, Nov 30, 2009 at 2:14:02 PM | Rendering wont do second cycle - revit arch 2010
ZSPTurbo
These are in my arch schools computer lab, so I can only assume everything is up to date.
Rendering problem with soft shadows on Revit Arch 2010
Wed, Jan 20, 2010 at 5:58:33 PM
Rendering function greyed out in Revit Arch 2009
Mon, Feb 16, 2009 at 4:53:18 AM
Walls Wont Show Up In View After Upgrading From 2010 To 2011
Tue, Dec 21, 2010 at 11:00:20 AM
Revit link wont stay linked
Tue, Apr 14, 2009 at 10:59:22 AM
Revit Arch 2010 lessosn wanted
Tue, Jul 7, 2009 at 2:44:34 AM
Page generation time: 1.5154
