Forums >> Revit Building >> Technical Support >> Shading with edges in Plan View
Mon, Nov 30, 2009 at 11:47:28 AM | Shading with edges in Plan View
RainaMc
RainaMc Avatar
Working in 2010.  Is there a way to make the walls be shaded in Plan View when you have it set to shading with edges?
Thanks for any help.
Raina Mc
Mon, Nov 30, 2009 at 12:16:17 PM | Shading with edges in Plan View
tim123
4 Stars: 19 Votes
It depends on the settings - if the view is set to fine it will show the colours set for the individual layers.  If it's course then it takes the colour set under 'Course scale fill color' for the whole wall.  You can override the view settings of walls to be other than that of the wall in VG.
Tue, Dec 1, 2009 at 9:15:29 AM | Shading with edges in Plan View
RainaMc
RainaMc Avatar
" You can override the view settings of walls to be other than that of the wall in VG"
That is what I needed thanks.
shading with edges problem
Wed, Nov 17, 2010 at 6:49:49 AM
In shading w/edges mode, inserted window do not cut out of wall in plan view..
Thu, Jan 12, 2006 at 4:28:27 AM
Shading with edges in plan
Mon, Sep 8, 2008 at 4:18:14 AM
TOO DARK Shading with Edges Revit 2009
Mon, Aug 25, 2008 at 6:57:19 PM
11
viewing structural, architectural & hvac in 3d with shading and edges
Tue, Apr 20, 2010 at 5:53:58 AM
Page generation time: 2.3880
