Forums >> Revit Building >> Technical Support >> RENDER NOT HAPPENING...
Tue, Aug 30, 2005 at 8:38:27 AM | RENDER NOT HAPPENING...
fazerneil
4 Stars: 5 Votes
Have done a scheme for a house. Last worked on it a week ago when it would render ok. Have opened up drawing today and now the render will not work despite not having changed any settings. When I try to render, it just goes back to the command prompt (as it where!) and waits for next command. Has anyone come across this ? I have imported a couple of cars (from this site) but have now removed these, purged and refreshed. These are the only potential cause of the problem I could think of but render still does not work. Other projects are still rendering ok so I know it is file specific ????
Tue, Aug 30, 2005 at 4:37:19 PM | RE: RENDER NOT HAPPENING...
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I have experienced this also. Have never been able to diagnose the cause and its typically been on large files. Usually decides to work again after a few days of working on it... Have you tried it on another PC? I think the quickest fix you are going to get will be sending to support...
Tue, Sep 20, 2005 at 5:00:45 AM | RE: RENDER NOT HAPPENING...
fazerneil
4 Stars: 5 Votes
I found the problem at last. Trial and error as usual. In revit 8 it was the fruit tree family. Whenever I got rid of these the render worked. When I put them into a project the render did not work. It has taught me to regularly test rendering is ok after loading families into projects.
Elements Missing in Render Image
Mon, Sep 27, 2010 at 7:21:17 AM
Revit render solarized?
Wed, Apr 17, 2013 at 9:50:43 AM
Render Calculation Error? [ 1 2 ]
Fri, Jun 7, 2013 at 7:53:38 AM
19
Render goes ok but when i change angle - the render is black
Tue, Oct 20, 2015 at 4:38:11 AM
Revit render or 3ds max design render?
Sun, Jan 4, 2015 at 10:19:29 AM
Page generation time: 0.2261
