Forums >> Revit Building >> Technical Support >> Dimensions Disappearing
Tue, Nov 24, 2009 at 9:41:18 AM | Dimensions Disappearing
Rayk123
I am using Revit Structural 2010 and in one of my models I have a linked model. When I dimension this part of the model (the linked features) all seems fine. But when others open their models they have to delete my dimensions to open. My local model has this linked file, and their models actually turn into the Central Model when I try to link theirs tom my file model.
Tue, Nov 24, 2009 at 11:10:22 AM | Dimensions Disappearing
You have some serious problems.  No file can turn into a central unless you do it.  And nobody should be working in a central.
When you say " they", is they someone in your office or elsewhere?  Who has the link and where does it reside?
Tue, Nov 24, 2009 at 11:27:25 AM | Dimensions Disappearing
Rayk123
We have Architectural who set up the Central model and the Local Files. When I link any one of the Arch models to my model, it calls itself Central Model, not their own local file name (no matter who's I bring in). It was set up by them (they). I agree no one should be working in it. I would normally have my own local file to work on but due to these complications I had to create a seperate model, then link it into my local file.
Tue, Nov 24, 2009 at 12:07:57 PM | Dimensions Disappearing
Your posts sounds like you do not understand the central/local file process.  To better understand this, refer to your HELP.
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
dimensions disappearing
Wed, Nov 28, 2007 at 9:42:54 AM
Disappearing Callouts
Thu, Feb 14, 2008 at 11:36:27 AM
window frames disappearing
Thu, Aug 18, 2005 at 3:05:08 PM
Text Background Mask Disappearing in PDF's (Revit Architecture 2009)
Thu, Feb 12, 2009 at 1:29:29 PM
Page generation time: 0.4132
