Forums >> Revit Structure >> Technical Support >> EXTRUSION YES/NO PARAMETER
Tue, Nov 24, 2009 at 9:16:42 AM | EXTRUSION YES/NO PARAMETER
gregroberson
gregroberson Avatar
IS IT POSSIBLE TO ASSIGN YES/NO PARAMETER FOR VISIBILITY ON FAMILY EXTRUSIONS AND/OR VOIDS.  I CAN EDIT THE EXTRUSION AND SELECT THE LINES AND EQUATE THIER VISIBILITY TO THE YES/NO PARAMETER.  HOWEVER, THE VOIDS ARE STILL GENERATED WHEN THE CHECK BOX FOR VISIBLITY IS UNCHECKED.
THANKS IN ADVANCE.
GREG
Tue, Nov 24, 2009 at 9:48:21 AM | EXTRUSION YES/NO PARAMETER
TKennedy
4 Stars: 8 Votes
No, you cannot assign a visibility parameter to voids.
Tue, Nov 24, 2009 at 10:00:47 AM | EXTRUSION YES/NO PARAMETER
gregroberson
gregroberson Avatar
BUMMER.  THANKS FOR THE REPLY.
Wed, Nov 25, 2009 at 3:38:06 AM | EXTRUSION YES/NO PARAMETER
Dafpfy
3.5 Stars: 11 Votes
if(name of your yesno parameter, 100 mm, 0 mm)
100mm is yes, 0mm is no
you can link this parameter to the end of your void and set your start at -50 ( outside of the object you whant to cut )
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Wed, Nov 25, 2009 at 7:25:39 AM | EXTRUSION YES/NO PARAMETER
gregroberson
gregroberson Avatar
Great.  I am not sure how to apply "if" statements to parameters.  I am excited to find out that it is possible.  Do you know of any literature on applying the "if" statement?
Wed, Nov 25, 2009 at 7:37:03 AM | EXTRUSION YES/NO PARAMETER
You can read your HELP for proper syntax.
What Dafpfy has suggested is very good.  In essence, you move the void off the object.  You can find an example of this though process in the countertop with hole family.  That void location(hole) can be moved off the counter using instance parameters which you see as grips when you place the family.
Wed, Nov 25, 2009 at 8:13:59 AM | EXTRUSION YES/NO PARAMETER
gregroberson
gregroberson Avatar
WWHub,
Do you have this family available?  I cannot find one in my library and I downloaded (Countertop_Prefab_bullnose_3_sides_with_square_lav_holerfa_3357.rfa) from this site, but I don't think this is what you were referring me to.
Greg
Wed, Nov 25, 2009 at 9:18:07 AM | EXTRUSION YES/NO PARAMETER
It is in your content under casework/domestic bathroom/Vanity Counter Top w Round Sink Hole.rfa  there is also a square hole.,
Wed, Nov 25, 2009 at 9:26:38 AM | EXTRUSION YES/NO PARAMETER
gregroberson
gregroberson Avatar
Thanks again.  I have not had a chance to check out the countertop family; I will shortly.  I did figure out the post by Dafpfy after WWHub's reply.
 I don't think I would have ever figured out the solution I was looking for without your guys help.  Your input was invaluable and I can't thank you both enough.
Wed, Nov 25, 2009 at 12:40:31 PM | EXTRUSION YES/NO PARAMETER
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I thought that this would make a nice tutorial tip.
See link below. . . .
Wed, Nov 25, 2009 at 2:03:22 PM | EXTRUSION YES/NO PARAMETER
Your usual good work ... thanks Daryl
Mon, Apr 28, 2014 at 4:04:36 PM | EXTRUSION YES/NO PARAMETER
LukeOrner
This is possible. Create a yes/no parameter, named whatever you'd like. While in the family editor, click on the extrusion/void you would like to control the visibilty of... in the properties box, the word "visible" is shown, to the right of that word is a box, click this box. A window will appear where you can apply the yes/no parameter you created to the visibility of that element. When you load the family into a project, if the box is checked, it will be visible, if it is unchecked, it will not be visible. Hope this helps.
Edited on: Mon, Apr 28, 2014 at 4:05:26 PM
Applying a Family Parameter
Tue, May 1, 2007 at 6:16:48 AM
top/base constraint as a parameter in family types
Wed, Sep 9, 2009 at 4:49:38 PM
Void extrusion family visibility
Fri, Apr 22, 2022 at 7:57:52 AM
Copy/array an extrusion in the "depth" direction
Thu, Sep 9, 2010 at 11:57:10 AM
Window parameter for overhead door
Fri, Apr 3, 2009 at 7:50:10 AM
Page generation time: 0.2122
