16 Users Online (15 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stairs (2010) only visible in plan
Mon, Nov 23, 2009 at 12:33:48 PM | Stairs (2010) only visible in plan
beccabecca11
I have created a new stair - but it only shows up in my plans - not sections or 3d.
I've checked VG in all views - stairs are set to be visible.  I've also checked that the stairs are created in "existing" and VP is set to "show existing".
 Is there something that I am missing?
Mon, Nov 23, 2009 at 12:48:01 PM | Stairs (2010) only visible in plan
Anna2010
Did you see if it was just hidden? try the reveal hidden elements.
Mon, Nov 23, 2009 at 12:55:05 PM | Stairs (2010) only visible in plan
beccabecca11
yeah - they don't show up as hidden either...
I shut down and restarted - no dice
Mon, Nov 23, 2009 at 1:07:06 PM | Stairs (2010) only visible in plan
You have turned them off someway.  Could they be in a different phase?... A design option that is off?  You have made sure they are on in VG?
This is a normal Revit stair - not a mass?
Mon, Nov 23, 2009 at 2:30:48 PM | Stairs (2010) only visible in plan
beccabecca11
thanks - it has something to do with phase filters.... if I change the filter to "none" they show up.  I will just have to figure out how better to set up existing/demo/new phases....
Walkthrough - Stairs not visible
Wed, Feb 21, 2007 at 9:39:11 AM
stairs wont demo off my plan
Wed, Aug 13, 2014 at 3:16:05 PM
truss not visible on framing plan
Mon, Apr 27, 2009 at 4:28:30 PM
Newly drawn model lines not showing up in Floor Plan (revit 2010)
Tue, Dec 21, 2010 at 10:06:04 AM
Floor Slab not visible in Plan!
Tue, Nov 9, 2010 at 1:58:17 PM
Page generation time: 0.5055
