10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Revit 2010 incorporating structural elements into architectural model
5 Posts No Rating |
I'm using revit 2010 and i have designed a floor plan which i have all interior and evterior walls and door openings and all walls are cmu with furring on the interior and brick veneer on the exterior and now i have to incorporate structurals model in to our model. What i'm running into is i have structurals models and they have drawn the interior walls and exterior walls also in their model but only the cmu portion along with any columns and framing. Now my question is how do i incorporate their model into mine? Is there a way to use their walls and for me to add the furring and brick veneer to the walls that need it in my model? Any help is appreciated. Thanks
You could copy/monitor their walls and add your furring walls (furring and finish only)... then join geometry.
Monitoring Non-Copied Structural Elements |
Wed, Jun 25, 2014 at 10:27:34 AM
Manipulate Structural Grid in Architectural model |
Mon, Nov 14, 2011 at 4:11:47 PM
visibility of reinforcing from linked structural model in architectural sections |
Thu, May 29, 2008 at 3:44:37 PM
Linked Structural model not visible |
Fri, May 3, 2013 at 11:49:54 AM
Making structural elements which cut architectural models. |
Tue, Aug 4, 2015 at 7:23:39 PM
