Forums >> Community >> Newbies >> wall floor finishing joint
Mon, Nov 23, 2009 at 1:35:32 AM | wall floor finishing joint
yosab
hi, hope every body is having a good time,
i have a problem, i cant make the floor finishing stop underneath the wall ( floor finishing should not go under wall structure !) , is there a way to make it stop and make the wall structure go down ?
Mon, Nov 23, 2009 at 4:03:21 AM | wall floor finishing joint
4 Stars: 205 Votes
In the properties of the slab, check if you have the "Finishing Layer" outside the "CORE" then did you try to use the "Join Geometry" tool in the Wall and slab???
Mon, Nov 23, 2009 at 4:56:30 AM | wall floor finishing joint
yosab
 thx Typhoon,
i tried join and it worked just great, thanks again,
finishing problems
Tue, May 17, 2011 at 6:05:41 AM
Changing wall finishing thickness without having to align it again
Tue, Jul 3, 2018 at 10:42:11 AM
room tag floor/wall/ceiling finishing
Mon, May 31, 2010 at 9:59:06 AM
How do you hide the joint lines between different wall types?
Fri, Nov 16, 2007 at 8:16:34 AM
wall joint in plan view
Wed, Feb 16, 2005 at 10:50:01 AM
Page generation time: 2.9209
