Forums >> Revit Systems >> Technical Support >> Default insulation on pipes
Sun, Nov 22, 2009 at 12:31:51 PM | Default insulation on pipes
koolair
4.5 Stars: 2 Votes
Hi, I was just notified that we are insulating all sanitary piping in the building (above & below ground...don't ask=)
That's what they want, so I need to quickly have everything sanitary shown with 1" insulation.  I'm hoping there is a setting (aside from r-click properties...doesn't pick up fittings...that's a separate operation).
How about my future sanitary pipes??  Is there a mechanical setting that gives me a specified insulation on pipes and fittings as I draw them?
Thanks,
Joe
Tue, Nov 24, 2009 at 3:52:06 PM | Default insulation on pipes
JillBernhardt
5 Stars: 3 Votes
Hello, I just did a little experiment that you might try to see if it suits your needs.  If you select one of your pipes that belongs to a Sanitary system, right-click and select "Select All Instances, you should just get all the sanitary pipe in the current view selected, no matter what the size. You can then go the Instance Properties dialog box and assign the insulation thickness you need to all of your sanitary pipes in this view.  In my little test, I ran this a second time and picked up all my sanitary elbows.  However, you would need to run it again for different kinds of fittings so be careful. Also, remember that you will need to add insulation to any new pipes or fittings that you add.
Next, issue you might have would be the display of different linework for the insulation.  You can assign that either in the Object Style for Pipe > Insulation to create a default for the entire project or set it in Visibility/Graphics for the current view only.
You may wish to show the pipe outer diameter as well as the insulation.  You you can do that in a Wireframe, Model Graphics Style, but, that may not be how you wish to display all of the other objects in the current view.  You can circumvent this by creating a Filter for just your Sanitary pipes and pipe fittings and checking on Transparent to display the sanitary pipe hidden by the insulation.  Be advised that a transparent pipe will not generate hidden lines for the objects the pipe passes above.  It is as if a transparent pipe is made of glass.  You can also turned off the pipe centerline  if you set the pipes transparent either in Visibility/Graphics or Objects Styles.
Once you are satisfied with the display settings in a view, you may wish to right-click on the View name in the Project Browser and select "Create View Template from View..." to save your display settings and apply them to a different view or views in the future.
Jill Bernhardt
    Blog:  The BIM Bulletin
Duo pipes - Twin pipes for central heating
Wed, Jan 16, 2019 at 3:48:53 PM
Plumbing insulation
Thu, Feb 20, 2014 at 8:19:48 AM
insulation line
Fri, Dec 1, 2017 at 9:57:58 AM
Hide insulation in MEP 2012
Wed, Sep 5, 2012 at 3:39:14 AM
REVIT MEP 2012 Demo Phasing Disconnecting Pipes
Wed, Jul 18, 2012 at 12:20:02 PM
Page generation time: 0.7730
