14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Moving project to align with Revit Structural File
37 Posts No Rating |
Early on in the project, I moved my model to where the AutoCAD site plan came in. After many discussions and a ton of problems, I now know that being too far from the origin is a VERY bad thing. Regardless, the structural engineer has his model at the origin point and just drags the architecture model into place. Is there a way to move my revit model to align with his structural model??? Relocate project keeps moving the origin point relative to the distance I move the project so that doesn't help - and if I use the move command, I leave behind all the annotation and grid lines etc. Is there any solution to this mess I've created???
1 Posts No Rating |
Did you find a solution to this problem? I am in the same situation now.
I did not for that specifc issue. I found a video tutorial on the proper way to work with the site plan using shared coordinates by Steve Stafford which is excellent. If you send me your email address I can send you a link to SugarSynch where you can download it.
This is your solution
http://paulaubin.com/_downloads/2011_AU/Papers/AB3733_Aubin_SharedCoord.pdf
Structural Analysis-DefaultCANENU.rte |
Mon, Jan 23, 2012 at 1:02:02 PM
Request - Complete Revit Project (Architectural, Structural, MEP) |
Tue, Oct 27, 2015 at 7:35:22 PM
structural Modeling in Architecture File |
Wed, Nov 26, 2025 at 11:33:49 AM
14
Query regarding Linked Structural revit model |
Mon, Apr 8, 2013 at 7:23:44 AM
Structural engineer sharing a file with Architect |
Tue, Jun 24, 2008 at 11:23:52 AM
