Forums >> Revit Building >> Technical Support >> Lost Keynote
Fri, Nov 20, 2009 at 6:29:14 PM | Lost Keynote
jwinger9999
I'm working on a project where we are using Keynotes for our building section, and recently I needed to re-keynote the view and I went through and deleted all the keynote bubbles in the view, even those associated with hidden objects.  The keynote legend cleared out, except for 1 note, and I cannot find it.  I need Help!  Are there tricks to possibly selecting it or somehow locating it so that I can remove the item?
Sat, Nov 21, 2009 at 6:30:07 PM | Lost Keynote
jarosa
jarosa Avatar
4 Stars: 5 Votes
this works for text types. Place the exact keynote that you want to delete. Right click, then select all instances and then delete.
Sat, Nov 21, 2009 at 7:28:57 PM | Lost Keynote
jwinger9999
Unfortunately since its not a text keynote, if I do that, it selects all keynotes on all sheets.  Found that one out the hard way.  Thank goodness for undo.
Tue, Oct 11, 2011 at 11:39:25 AM | Lost Keynote
ntakibazo
I've been having this same problem - one keynote remaining in the legend after all instances of that particular keynote being cleared off the sheet. Anyone ever find a solution for this problem?
Wed, Jul 26, 2017 at 2:12:25 PM | Lost Keynote
aandr001
4.5 Stars: 6 Votes
How's this for a late answer!  Only 6 years Late!!
First select the element that you've keynoted, then select any other element keynote.  Click on your little sunglass icon and say isolate catagory.  This will leave the object and the hidden keynote on, which you can then delete.  It might be a good idea to turn your crop region off as well just in case the keynote ended up outside the view you have.
keynote categories
Fri, Aug 10, 2012 at 3:56:23 PM
Multiline keynote
Thu, Jan 8, 2009 at 2:31:33 PM
Keynote Legend Not Showing Keynote Text
Fri, Sep 6, 2013 at 11:40:59 AM
12
Keynote Text in Schedules
Thu, Sep 11, 2014 at 4:45:04 PM
Keynote Data problem
Wed, Feb 2, 2011 at 2:35:58 PM
Page generation time: 0.5207
