Forums >> Revit Systems >> Technical Support >> PIPE COLOR
Fri, Nov 20, 2009 at 9:57:39 AM | PIPE COLOR
GMMcCrossin
I HAVE AROUND 10 DIFFERENT PIPE SYSTEMS FOR A WWTP I AM WORKING ON. I WOULD LIKE TO MAKE THE PIPE DIFFERENT COLORS FOR MY GUYS IN THE FIELD SO THEY CAN FOLLOW IT. IS THERE ANYWAY TO ADJUST RENDERED APPERENCE OR COLOR FOR EACH SYSTEM? i AM WORKING WITH REVIT MEP 2010 ANY HELP WOULD BE GREAT............
THANKS,
LANCE S
Fri, Nov 20, 2009 at 11:30:44 AM | PIPE COLOR
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I usaully create filters with different colors for each type of system. Then I just set the filter to read the COMMENTS property of all the families in the pipe catagory. Then in the view(s) I add the filters in the visibility / graphics dialog and then just type in the comments property the abbreviation for the system.
See the attacched images for examples.
HTH
Edited on: Fri, Nov 20, 2009 at 11:32:31 AMEdited on: Fri, Nov 20, 2009 at 11:32:56 AM
Edited on: Fri, Nov 20, 2009 at 11:33:20 AM
69157_Filter_Dialog.jpg69157_System_Example_1.jpg69157_System_Example_2.jpg69157_Filter_Dialog.jpg69157_VisibilityGraphics.jpg
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Nov 20, 2009 at 11:33:46 AM | PIPE COLOR
brettgoodchild
4 Stars: 17 Votes
I like this filter image better.
                             ~ Abraham Lincoln
Fri, Mar 12, 2010 at 1:01:24 PM | PIPE COLOR
vinnygolfer
4.5 Stars: 4 Votes
ok, i have another question regarding filters for pipe types.   do i really have to go into each and every pipe, and fitting, and add text to the comment line. for example Vent, or Storm. to make them different from Sanitary Drain?
Try to learn at least one new thing every day
Fri, Mar 12, 2010 at 1:09:05 PM | PIPE COLOR
brettgoodchild
4 Stars: 17 Votes
No.
 If you go to the analyze tab, you cna place a colorfill based on certain properties of the pipes...then just add that colorfill to the desired views.
                             ~ Abraham Lincoln
Fri, Mar 12, 2010 at 1:28:22 PM | PIPE COLOR
vinnygolfer
4.5 Stars: 4 Votes
i must be missing something. in the analyze tab. the only color scheme that i can apply is the pipe size. and in section view, that is even blocked. i'm getting frustrated. if i use the filter set up for system type sanitary, and comment vent. then the sanitary overrides the vent and both are green, unless i uncheck the sanitary. then the drain is white. still not right. i'm pulling out my hair.
Fri, Mar 12, 2010 at 1:39:17 PM | PIPE COLOR
vinnygolfer
4.5 Stars: 4 Votes
i know that what i want to do is possible, i just can't seem to be able to figure it out. on a totorial that i saw from autodesk au. they have somehow defined a pipe type for vent. and when they connect a pipe to the vent connection, it automatically changes to orange.
Thu, Apr 1, 2010 at 9:50:48 AM | PIPE COLOR
LukeChiavelli
I know this thread is a few months old, but for anyone else out there refering to this I have a suggestion.
 Rather than use "Comments" in your filter, use "Type Comments" This will allow you to define the pipe type such as Cold Water and everything you draw that is defined as that will take on those properties. That will allow you to not have to select each item one by one.
 Also, if you have pipe that is already drawn that has no properties assigned to it yet you can use MA to match atributes similar to match properties in AutoCAD.
Thu, Apr 1, 2010 at 10:43:51 AM | PIPE COLOR
vinnygolfer
4.5 Stars: 4 Votes
thank you sooo much.
Set color of a pipe in 3D without the pipe tool
Fri, Dec 17, 2010 at 10:40:54 AM
Pipe Accessories and Pipe Type parameter
Tue, Dec 27, 2011 at 11:25:39 AM
Pipe size
Fri, Jan 21, 2011 at 11:27:02 AM
Revit MEP 2013 - How to hide cross hair on pipe while showing pipe centerline?
Thu, Jun 12, 2014 at 6:37:39 AM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
Page generation time: 1.6674
