Forums >> Revit Building >> Technical Support >> Can I make part of a family invisible?
Fri, Nov 20, 2009 at 8:50:40 AM | Can I make part of a family invisible?
ldonkle
Example: Our Washers & Dryers are 2'7" deep, but require 4'3" depth of clearance.  Can we add a "guideline" to our Washer/Dryer families so our designers can see the required 4'3" depth? (but NOT have this "guideline" appear on plans)
Fri, Nov 20, 2009 at 9:48:47 AM | Can I make part of a family invisible?
Add an invisible line to the family ... but be aware that this line is part of the family and if any part of the family is in another room, the family will be scheduled accordingly.
This line will only shown when the item is picked.
NOTE... You can change your family insertion point... reference plane to be in this location so the family is inserted in the right place.
Edited on: Fri, Nov 20, 2009 at 9:50:48 AM
Fri, Nov 20, 2009 at 10:09:50 AM | Can I make part of a family invisible?
TKennedy
4 Stars: 8 Votes
Something that we have been doing with our kitchen equipment is making a new object style subcatagory in the family and calling it clearance. It has a dashed linetype, and you can go to V/G and turn it off in any view you don't want to see it.
Fri, Nov 20, 2009 at 10:39:48 AM | Can I make part of a family invisible?
That was a better answer TKennedy
Fri, Nov 20, 2009 at 10:43:55 AM | Can I make part of a family invisible?
ldonkle
Tried both ways - I wish the lines in TKennedy's method also appeared when the item is picked (like WWHub's invisible lines do) but it's simple enough to turn them on in V/G settings.  Thanks.
Linework only for part of edge
Tue, Apr 21, 2009 at 8:06:51 AM
Invisible Dimension Lines
Thu, Dec 29, 2011 at 6:04:48 PM
Invisible Masking Region outline
Tue, Jul 12, 2016 at 12:11:33 PM
Rendering an invisible wall.
Sun, Apr 24, 2011 at 12:01:49 PM
Invisible lines removed from Line Styels
Mon, Feb 21, 2011 at 12:10:18 PM
Page generation time: 3.5537
