Forums >> Revit Building >> Tips & Tricks >> Placing 3d Model Text on a Curved Wall
Fri, Nov 20, 2009 at 7:57:24 AM | Placing 3d Model Text on a Curved Wall
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You cannot place model text on a curved wall but you can place model text on reference planes so the work around is to create a series or reference planes tangent to the curved wall and place one letter on each reference plane. Takes a little bit of time but it works.
In the example shown below I named each reference plane according to the appropriate letter ie: ‘M’ ‘O’ ‘D’ ‘E’ ‘L’, then 'set the current reference plane' before placing the model text letter.
You can fine tune the ‘plan’ positioning by moving or rotating the reference planes after the letters have been place. You can also nudge the letters around within the reference plane.
Did you know you can 'rotate' a reference plane ??
I changed the ‘material’ of each letter to achieve the color effect.
See images below.
Edited on: Fri, Nov 20, 2009 at 7:58:43 AM
Sat, Nov 21, 2009 at 5:54:42 AM | Placing 3d Model Text on a Curved Wall
tim123
4 Stars: 19 Votes
You can also use the circular array with reference planes, so another method is to create a reference plane and host a single letter to that plane.  Use the array to create the copies of the reference plane and individual letter.
Model Text on Curved Wall
Tue, Dec 21, 2010 at 7:58:21 AM
Model Text and Curved Walls
Fri, May 18, 2007 at 9:29:50 AM
Wed, Dec 8, 2004 at 2:20:21 AM
Curved Model Text
Wed, Feb 8, 2006 at 3:34:25 PM
Curved Model Text
Fri, Apr 5, 2013 at 2:10:34 PM
13
Page generation time: 2.7512
