11 Users Online (9 Members):
Forums >> General Discussion >> Revit Project Management >> Is there a way to have the current date print out on the title block?
Is there any kind of datestamp within revit, like within Autocad, to generate the current date when plotting? I saw that I can make custom fields within the titleblock, and those fields can be updated manually to change the date. I am looking for a more foolproof/automatic system if it exists. Anything out there?
Create a label and use the date/time stamp parameter, it will update themselves when you use the titleblock. I like to also have another label with the file path parameter so I can tel where the plot came from.
Edited on: Thu, Nov 19, 2009 at 1:35:09 PM
Perfect! Thank you.
0 Posts No Rating |
Is there a way to have a date stamp that doesn't include the time?
If you look, you will only see Date/Time.
Visable Line that doesnt print - Title block |
Wed, Aug 13, 2014 at 7:01:35 PM
Current date in formula on titleblock |
Tue, Oct 9, 2012 at 8:09:59 AM
Title Block - How to create a new label? |
Fri, Apr 20, 2012 at 10:51:03 AM
Title block labels |
Thu, Sep 23, 2010 at 6:09:42 PM
Current Revision Date in sheet index |
Mon, Nov 2, 2009 at 11:22:28 AM
