27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Inconsistent data in DWF exports
I've been experimenting with the 3D DWF feature for a project but Revit (RAC2009) has been inconsistent with it's data exporting. I have about 11 additional parameters that I have added in Revit for Facility Maintenance info. Every item in the project has these parameters since it's set up globally. When I export to DWF quite a few of the objects no longer have this info attached to them. For examle I have 4 different window types and when I export, 1 window type has the standard info attached with the additional info included, 1 type has the standard info, and the rest have no info at all. Any ideas? Any help would be greatly appreciated.
And this info is all setup as shared parameters in each type?
They are set up as prjoect parameters. The odd thing is that in the model all items have these parameters, but when translated over some do and some don't. I did find that left blank some still don't have them, but if I fill them out in revit and then make a DWF they do come over. It's just the blanks that don't.
3D DWF export in Revit 2009 does not export identity data |
Thu, Nov 19, 2009 at 12:01:43 PM
Inconsistent Pi |
Sun, Mar 1, 2009 at 5:45:25 AM
DWF Linking |
Thu, Aug 23, 2007 at 12:55:32 PM
Revit views to DWF format to print |
Fri, Mar 19, 2010 at 12:21:41 PM
help! dwf for 2d plans |
Sun, Feb 26, 2006 at 8:15:57 PM
