Forums >> Revit Building >> Technical Support >> Timber panelling 3'-0" high within room Revit 2010
Thu, Nov 19, 2009 at 9:52:37 AM | Timber panelling 3'-0" high within room Revit 2010
2005Mark
3.5 Stars: 2 Votes
Hi,
I have created a village hall with ancillary rooms. Within the main hall I wish to include  timber panelling about 3'-0" up from floor level and then topped by a dado rail of some sort. What is the best way to achieve this. Thanks in advance to all.
reagrds
Mark
Thu, Nov 19, 2009 at 12:42:34 PM | Timber panelling 3'-0" high within room Revit 2010
tim123
4 Stars: 19 Votes
There are two main methods to do this.  The first is to create as a layer in the wall properties and unlock the layer and stretch it down to the correct height in a section.  You could use a wall sweep to create the rail.  The second, which I prefer, is to create a seperate wall for the panel with a sweep for the rail and then align and join it to the main wall.
Thu, Nov 19, 2009 at 1:18:16 PM | Timber panelling 3'-0" high within room Revit 2010
I use the added wall method for something like this.  I believe the first method will cause you problems because I have seen the exterior wall finish applied to the secondary layer in some cases.  I don't know if that is true all the time but the thin wall works so well I don't need to do the other.
Thu, Nov 19, 2009 at 1:55:35 PM | Timber panelling 3'-0" high within room Revit 2010
2005Mark
3.5 Stars: 2 Votes
Thanks. I have made a new wall 40mm thick and called it panelling. Then in ground floor plan, I placed the panelling up against the existing wall. then I used the Join tool.
Thanks
Room Tag With Ceiling Offset from level, or Ceiling High
Sun, Mar 8, 2009 at 11:03:00 PM
Timber Shell Structure
Fri, Nov 30, 2012 at 3:39:18 AM
How would I go about creating a timber frame?
Fri, Feb 10, 2006 at 3:49:50 PM
Timber Framing
Tue, May 9, 2006 at 9:04:39 AM
Some questions.
Mon, Mar 27, 2006 at 8:46:10 PM
Page generation time: 4.8747
