Forums >> Revit Building >> Tips & Tricks >> QUICK RENDERING
Wed, Nov 18, 2009 at 9:31:33 PM | QUICK RENDERING
deboddy
5 Stars: 2 Votes
I  am still using RA2009, but am fairly confident this rendering trick should work for 2010 as well.
In Rendering  - Quality - Settings choose the one you want  for example 'Best', then click on 'Custom (view specific)', then on 'Edit'. A new screen will come up. No need to make any changes, just click OK.
Now choose your output settings - screen,printer etc and run it.
The render will run in a couple of minutes, rather than hours. I have only tried this for external renderings so far.
I don't know how it works, or why, but it is amazing!
Deb
Fri, Nov 20, 2009 at 7:56:17 AM | QUICK RENDERING
JimNoth
I just had to try this out because it seemed too good to be true.  Unfortunately, it is too good to be true.
If you're looking to do a "Best" quality rendering, the only way the "Custom (View Specific)" would render with the same quality is if you copy the settings of "Best" over to "Custom (View Specific)".  Once you do this and try the trick sequence of events, the rendering still takes just as long as it would normally take on "Best".  My guess is that if you check all of the render settings in your "Custom (View Specific)" selection, they will look eerily similar to "Medium" or "Low"... which certainly only take a few minutes, but look like garbage - comparitively speaking.
Either that, or the fact that I'm on 2010 actually DOES make a difference.
Quick rendering
Sat, Nov 26, 2016 at 10:37:42 AM
Revit will not finish rendering ???
Fri, Sep 25, 2015 at 7:09:30 PM
14
Rendering 2009
Wed, Jun 11, 2008 at 8:44:47 AM
3D rendering - quick and simple tips required
Thu, Aug 25, 2016 at 5:55:53 PM
Window Colors How to Adjust
Tue, Sep 24, 2013 at 9:31:21 PM
Page generation time: 0.9010
