Forums >> Revit Structure >> Technical Support >> Snapping to Details Lines?
Wed, Nov 18, 2009 at 2:43:01 PM | Snapping to Details Lines?
Wildcat7
Wildcat7 Avatar
This may be a remnant from my years in AutoCAD, I've been laying things out with detail lines in Revit then coming back and then trying to add model elements at the intersections of my details lines.  Why doesn't Revit allow me to snap to those detail lines?  Is there a setting I haven't found?  Or I just can't snap to detail lines when adding elements?
Wed, Nov 18, 2009 at 2:45:26 PM | Snapping to Details Lines?
My first question is why waste time with layout lines - you will just have to delete them later?  Use walls if a plan.
Revit will snap to almost anything - lear to use your tab key.
Wed, Nov 18, 2009 at 3:09:57 PM | Snapping to Details Lines?
Wildcat7
Wildcat7 Avatar
Why add walls?  There are no walls being used!  I still would need to delete them later!  I'm developing a canopy, the framing is all steel wide flange beams or channels . . .
Tried the tab key too . . . been there done that . . .
Thanks
Wed, Nov 18, 2009 at 4:08:01 PM | Snapping to Details Lines?
Sorry, you didn't say what you were using but the question is the same.  Just place the beams / channels - and either use the temp dimensions to get them in the right place or dimension them and then click on the object and when the dimension changes color change the dimensions to move the object.
As far as the snapping goes - I don't know what is happening for you.  My objects will snap to intersection / end points / mid points of detail lines when I go to place them.
Wed, Nov 18, 2009 at 4:23:18 PM | Snapping to Details Lines?
Wildcat7
Wildcat7 Avatar
I went back and replaced the detail lines with gridlines and my beam elements ends snapped to the intersections . . .
 Thanks!
Wed, Nov 18, 2009 at 4:28:19 PM | Snapping to Details Lines?
emgeeo
3.5 Stars: 7 Votes
You have the ability to snap to intersection, pependicular, end points, mid-points, etc. etc. etc. - just the same as you were able to in CAD.
Perhaps your snaps are turned off.  You can check them under the Settings -> Snaps menu.
As for snapping during commands- you can type in the keyboard shortcut for what you would like to snap to.  If you want to snap to and endpoint, type in SE while in the middle of your command.  If you want a mid-point, type in SM.  These shortcuts can also be viewed in the Settings -> Snaps menu (the shortcuts are in parenthesis.)
One other thing I'd like to point out is that you can access your snaps through your keyboard shortcuts.  You'll just have to assign a key to them.  I use the spanish accents key- because my fingers are always gliding between the escape key, tab, caps, shift, ctrl and alt.  These are the most useful keys in navigating revit IMHO.
Make sense?
Also, as for laying out beams on top of detail lines.  No, it doesn't make sense to do this, and it's a complete waste of time.  If there are grids associated with this canopy, you can use grid intersections to layout your columns, pad footings, piers, and girders.  You can use the copy command and dimensions to layout the rest of the framing after that.
However, if you can't seem to break that habit- which I strongly urge you to break because it is very very very inefficient- you can always use the pick command from your editing bar to place members along lines.  I do actually use detail lines to lay-out complex geometry and curves and use the pick option to place the actual elements.  But only on curved and complex geometry....
Make sense?
Thu, Nov 19, 2009 at 7:16:05 AM | Snapping to Details Lines?
Wildcat7
Wildcat7 Avatar
I know this . . . been there done that . . .
Nope I checked . . . .
Tried that too . . .
That's cool and thanks!
Make sense?
Yes . . .
Know you . . . I've been a draftman for over 35 years . . . we all have methods of drawing, so your comment that it doesn't make any sense . . . well, it's b*ll sh*t.  There are no grids associated, it's a canopy in space . . .
Thanks for your concern . . . In my opinion (sorry I didn't attached a PDF), but this is complex geometry . . . I wouldn't add detail lines if all the framing was on the gridlines . . . duh!
Make sense?
What do you think?
Thu, Nov 19, 2009 at 12:18:58 PM | Snapping to Details Lines?
emgeeo
3.5 Stars: 7 Votes
OK
Spot Elevations - Random snapping.
Tue, Feb 21, 2017 at 6:19:05 AM
Snapping and Detailing
Mon, Nov 11, 2013 at 3:54:58 PM
Exterior House Details
Mon, Mar 3, 2008 at 11:10:44 AM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Tidying up details
Thu, Dec 17, 2009 at 9:19:04 AM
Page generation time: 4.6926
