Forums >> Revit Building >> Technical Support >> Revit Export to AutoCad text issue
Wed, Nov 18, 2009 at 1:05:48 PM | Revit Export to AutoCad text issue
HGL5
When I export a revit file to AutoCad, all the text is hardcoded to be the specific font that came over from revit. This means I cannot globally change the font in AutoCAD to a .shx font. Instead I have to highlight each text and change the font manually. Anyone else ever have this problem and find a way around it? Thanks
Thu, Dec 16, 2010 at 1:33:10 PM | Revit Export to AutoCad text issue
missgayley
missgayley Avatar
i'm not only having this same issue, i cannot figure out how to change the text manually without having to explode it first.  which, of course, takes the mtext and turns it into multiple single-line text.
help?
(revit 2011 to acad 2010)
Thu, Dec 16, 2010 at 1:38:19 PM | Revit Export to AutoCad text issue
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
explode it twice then change it. takes all of about 10 seconds to do
Column Grid Text Exported into AutoCAD as Annotative Text
Wed, Jul 24, 2013 at 9:14:29 AM
MEP AutoCAD Export issues
Sun, Mar 13, 2016 at 12:46:02 PM
Exporting to Autocad government layers
Wed, Sep 29, 2010 at 5:01:45 PM
Text Problem when exporting to CAD
Mon, Feb 9, 2009 at 12:50:23 PM
Export Revit text to AutoCAD mtext
Thu, Jan 29, 2009 at 6:45:29 AM
Page generation time: 1.7583
