Forums >> General Discussion >> Revit Project Management >> project title block
Wed, Nov 18, 2009 at 10:49:01 AM | project title block
lifeisadrift
3.5 Stars: 2 Votes
okay so I made my company title block with all the parameters and all is working well. But for the project title I would like to make a sort of xref drawing that we would insert in to the title block. I would do it this way because we like to make the project title a little bit fancier and add the clients logo with some text that have a bigger width then others.
I want it to change on all pages at once if it needs some changes.
I tried making a family but it doesn't work
 Any suggestion's would be appreciated
Thu, Nov 19, 2009 at 4:22:21 PM | project title block
Edit your titleblock and insert it there ... project by project.
Tue, Dec 1, 2009 at 2:18:45 PM | project title block
MARS1276
1 Stars: 1 Votes
Here's another idea... what we have done is created a template titleblock and within that titleblock we use a drafting view of our company logo.  This is placed within our titleblock template so when we start any project we can load that titleblock in and it will have our logo already in place.  Drafting views can be inserted from one file into any project, so if you place other company's logos into your titleblock (I assume on an as needed basis), you may want to do this part as per the specific project.
Hope that helps.
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Title Block labels
Sun, Apr 8, 2007 at 10:04:03 PM
Help, Title block scale appear to be wrong and can not be changed
Mon, Aug 29, 2016 at 10:56:37 AM
In the default Revit Templates i couldnt find revit title block
Fri, May 23, 2014 at 7:22:23 AM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Page generation time: 0.5455
