Forums >> Revit Structure >> Technical Support >> Revit 2010 change font
Wed, Nov 18, 2009 at 7:36:10 AM | Revit 2010 change font
seniorcad143
1 Stars: 1 Votes
We are trying to set up a template and one item we want to change is the default font from arial to simplex.  how do we go about doing this, and can we do it in one easy step?  Or do we have to do it in several spots?  (simplex seems to have all the symbols that we normally use).
Yeesh - Where is My Cad
Wed, Nov 18, 2009 at 8:07:49 AM | Revit 2010 change font
seniorcad143
1 Stars: 1 Votes
now i can't get any of the symbols to work if I type in alt + 0216 (for diameter) using the default font.
Wed, Nov 18, 2009 at 8:59:22 AM | Revit 2010 change font
Revit uses only TTF fonts.  You can run Charmap from your start / run and then select your font style to see the mapping of the fonts available.  Read your help on text to see how to set up your text.
Wed, Nov 18, 2009 at 9:06:45 AM | Revit 2010 change font
seniorcad143
1 Stars: 1 Votes
I did go thru the help menu - it pops up the text type properties.
I thought arial was a true type font because it is the default in revit.
Apple MacBook Pro for sale with Revit 2010
Mon, Aug 24, 2009 at 2:18:56 PM
Revit 2010 - 3D max 2010 finishes
Wed, Jun 3, 2009 at 5:57:51 PM
How do I change the font in my local file?
Wed, Dec 5, 2007 at 9:32:56 AM
How do you change the font size and style on sheet detail titles?
Fri, Aug 24, 2007 at 8:24:56 AM
Change Line Color [ 1 2 ]
Fri, May 10, 2013 at 11:03:39 AM
17
Page generation time: 3.3287
