Forums >> Revit Structure >> Technical Support >> quantity of colums
Wed, Nov 18, 2009 at 6:33:35 AM | quantity of colums
lanskaja
Help me, please/
Can I count quantity of architectural colums by specification?
Wed, Nov 18, 2009 at 7:36:50 AM | quantity of colums
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You will get much better results by using 'structural' columns.
Thu, Nov 19, 2009 at 3:49:25 AM | quantity of colums
lanskaja
 Thanks, I know but I have to insert exactly architectural colums.
Thu, Nov 19, 2009 at 6:46:58 AM | quantity of colums
lanskaja,
I don't believe you understand.  "Architectural" columns are kind of mis-named.  They really act like pilasters and will assume the material of any wall they engage..  Structural columns can be concrete, steel or even other materials like brick.  In addition, you can have unique column families like doric or ionic...etc.  Any of these columns will schedule and count.
Fri, Nov 20, 2009 at 1:56:47 AM | quantity of colums
lanskaja
I see.
I think any object  in Revit I can count by schedule.
but I found out I can't count architectural colums, balusters....
Fri, Nov 20, 2009 at 4:48:19 AM | quantity of colums
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
For a quick turn around a small tip: Slect the Arch. column and click on Edit Family. From the Categories and Parameters select Structural columns and reload. Generate schedules for Structural columns, after getting results you can undo till load family.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Fri, Nov 20, 2009 at 4:50:10 AM | quantity of colums
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
I know select the column and click on select all instances is also much easier and faster option...but the above solution is for proper format.
Pavan Reddy
Revit Manager
Mon, Nov 23, 2009 at 2:36:32 AM | quantity of colums
lanskaja
Thank you
Revit 2009 - Quantity Take offs
Thu, Sep 9, 2010 at 4:41:22 PM
quantity of balusters
Tue, Nov 10, 2009 at 7:34:45 AM
Is Revit able to do serious quantity surveying stuffs?
Thu, Jan 20, 2005 at 12:03:33 AM
i need to show colums, bearing walls and primary structural grids in my revit..
Mon, Mar 31, 2014 at 7:57:09 AM
rebar reinforcement quantity take off
Mon, Apr 5, 2010 at 4:55:25 PM
Page generation time: 1.5225
