Forums >> Revit Building >> Technical Support >> The finish Schedule
Tue, Nov 17, 2009 at 5:03:45 PM | The finish Schedule
Snodaisy
Revit 2009
How can a finish (parameter?) be added to an element that will load into a finish schedule? I have a reoccuring element (not a wall, but an extruded object) that will be painted one of two colors. This paint information would need to add itself to the finish schedule. Will provide any additional info needed.
If it's not painfully obviously I am week 1 into teaching myself Revit. Calls to acquire teaching aside, I appreciate your patient input.
Thu, Nov 19, 2009 at 4:27:00 PM | The finish Schedule
Since it is early in your revit experience, spend some time understanding parameters - shared and project.  The HELP file will help a lot.
Next, spend some time in the help under schedules.  Almost everything in Revit can be scheduled but there are real limitations on the schedule format.  Room schedules for most of us end up with a lot of manual categories.  This sweep would be one of those.
Fri, Nov 20, 2009 at 12:35:27 AM | The finish Schedule
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
It may be easiest for you to look into making a TEXT finish parameter and just manually fill in the schedule.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Finish Schedule
Mon, Aug 10, 2009 at 6:25:50 AM
making a finish schedule
Wed, Feb 20, 2008 at 8:12:30 AM
Finish Material Schedule
Tue, Nov 29, 2005 at 12:31:59 PM
finish/ material schedule
Fri, Apr 25, 2014 at 12:30:26 PM
Room Finish Schedule by floor
Wed, Jun 20, 2007 at 8:55:28 AM
Page generation time: 2.1001
