11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Line Styles with Text
19 Posts No Rating |
How can I create a new Line Style that Contains text? I am trying to create lines to indicate locations of utility lines so I'm trying to a "SS" within the dashes to indicate "Sanitary Sewer"
As far as I know, you can't. You can have various lengths of dashes/dots, but no text. I would look into creating a repeating detail for what you want to do.
I can only assume that this is something that is overcome within the Civil Engineering version of Revit.
No true linetype. What you can do is create a line based detail component...or use this one. http://revitcity.com/downloads.php?action=view&object_id=6725 You can change the way the array works in the family, add parameters, etc.
here, use this... With this you can change the spacing of the text AND duplicate it to make a new linestyle type and edit the text to say what you want it to. I developed it for our office and we have found it really great to use and really nice when we want all of the lines to appear spaced equally... or, in some cases, if we want to space the text so that it does not cover and hide a topo elevation number. Hope this helps!
Also, please let me know if this works for you; and, if so, let me know what you think.
I'll give it a try. Thanks
Removing Line Styles |
Mon, May 8, 2017 at 2:21:04 PM
Associating Line styles with patterns |
Tue, Sep 18, 2012 at 11:30:05 AM
Deleting Line Styles |
Tue, Aug 5, 2014 at 2:57:29 PM
Removing Text Styles |
Mon, Sep 19, 2011 at 12:17:03 PM
Deleting an Inherited Text Type |
Fri, Nov 4, 2005 at 8:05:05 PM
