Forums >> Revit Structure >> Technical Support >> Need help with window?
Tue, Nov 17, 2009 at 1:49:09 PM | Need help with window?
rex916
Hello, I'm creating a window opening Cryingstarted off with generic model wall based template) that shows header, sills, and detail components when cut in section. I set up parameters for the header height (ref level to bottom of header), opening width, opening height, and sill height (ref level to top of sill). Everything flexes good within the family. The one problem I have is when I load it into a project and try to change the type of the window to a different type             (from 3'-6"x3'-6"xHH7'-10" to a 4'-6"x4'-6"xHH8'-0"Winking (HH stands for header height) , revit disregard where my header is located. (Example: within my family, header parameter is set to 7'-10", but when I change it inside the project to show the header at 8'-0", revit makes the change and puts my header at a different height than 8'-0"Winking.
So within my project, the only way to get the header to show at the correct spot, I have to click the window opening, element properties, and under constraints, change the sill height to equal (Header Height minus Opening Width).
So my question is, Is there a way for revit to automatically show my header at the correct elevation when changing to a different window type? I don't want to change the sill constraints everytime I make a change to a window type. Any help will be appreciated. Thanks
Tue, Nov 17, 2009 at 1:59:10 PM | Need help with window?
rex916
I have a correction to my post, the sill height equals Header Height minus Opening Height minus Sill Height.
Tue, Nov 24, 2009 at 1:38:33 PM | Need help with window?
rex916
I fixed my problem. Thanks for all the help anyways.
Window sashes with different window numbers in the window schedule
Tue, Mar 19, 2024 at 11:49:53 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:36 PM
LOOKING THROUGH THE WINDOW, SCHEDULE
Sun, Dec 19, 2004 at 7:03:39 PM
WINDOW FAMILIES
Thu, May 24, 2007 at 5:46:09 PM
Window's dimension don't show up in the window schedule
Fri, Aug 17, 2012 at 1:34:43 PM
Page generation time: 0.1882
