Forums >> Revit Building >> Tips & Tricks >> Free Video CADclip on Creating a REVIT Family Type Catalog File
Tue, Nov 17, 2009 at 1:35:13 PM | Free Video CADclip on Creating a REVIT Family Type Catalog File
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
The majority of REVIT families should take advantage of 'Type Catalogs'.
This helps in all 3 REVIT disciplines in 3 great ways.
1. You can quickly create 10's to 100's of family types.
2. You can load only the types you need when you load the family.
3. It keeps the project file size down.
ENJOY the CADclip link below !
 http://www.youtube.com/watch?v=2tWlBSc7ijo
Edited on: Tue, Nov 17, 2009 at 1:35:49 PM
Tue, Nov 17, 2009 at 2:08:02 PM | Free Video CADclip on Creating a REVIT Family Type Catalog File
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Thanks dgcad...............
Tue, Nov 17, 2009 at 2:13:22 PM | Free Video CADclip on Creating a REVIT Family Type Catalog File
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'm always surprised at how many people DO NOT use type catalogs. The inch symbol " can stop you in your tracks however if you don't know that you have to double it up > ""
Tue, Nov 17, 2009 at 4:05:51 PM | Free Video CADclip on Creating a REVIT Family Type Catalog File
TKennedy
4 Stars: 8 Votes
Thanks dgcad, that's great! the only question I have is where was this a month ago when I jumped into type catalogs?
There are a couple things that I have found and would like to share. One, notpad works great with  families with just a few, easy to manage parameters, and for quick edits. I have found it can be a big help to work in Excel, which will break each parameter into its own column. You have to save a .csv file, but if you change the extension to .txt it works fine. another thing is to put quotes around values for text parameters (Description, for instance), otherwise you will get all sorts of errors when you need to put a comma in the description.
Tue, Nov 17, 2009 at 7:23:56 PM | Free Video CADclip on Creating a REVIT Family Type Catalog File
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Excellent. Yes Ecxel makes organizing columns much easier.
Double quotes, double double quotes or single quotes?
Can you cut and paste a sample (including header) for our readers?
It's a great topic usable by all REVIT users.
I have no doubt that many users have tried, failed and given up on 'type catalog' files.
Here is the file I use in the video.
ARCH-WINDOW-TUTORIAL.txt
,Width##length##inches,Height##length##inches,ARC Rise##length##inches,Batten Width##length##inches
4'-0"" x 4'-0"" x 6"" x 4"", 48, 48, 6, 4
4'-0"" x 3'-0"" x 6"" x 6"", 48, 36, 6, 6
4'-0"" x 2'-0"" x 6"" x 8"", 48, 24, 6, 8
4'-0"" x 4'-0"" x 12"" x 4"", 48, 48, 12, 4
4'-0"" x 3'-0"" x 12"" x 6"", 48, 36, 12, 6
4'-0"" x 2'-0"" x 12"" x 8"", 48, 24, 12, 8
4'-0"" x 4'-0"" x 18"" x 4"", 48, 48, 18, 4
4'-0"" x 3'-0"" x 18"" x 6"", 48, 36, 18, 6
4'-0"" x 2'-0"" x 18"" x 8"", 48, 24, 18, 8
3'-0"" x 5'-0"" x 12"" x 4"", 36, 60, 12, 4
3'-0"" x 6'-0"" x 12"" x 6"", 36, 72, 12, 6
3'-0"" x 7'-0"" x 12"" x 8"", 36, 84, 12, 8
Edited on: Tue, Nov 17, 2009 at 7:27:13 PM
Type Catalog
Mon, Mar 13, 2006 at 1:58:57 PM
adding parameters to a family with a type catalog
Thu, Feb 19, 2009 at 11:10:20 AM
type catalog
Fri, Apr 8, 2005 at 2:35:30 PM
Family Type Catalog
Sat, Jan 10, 2015 at 9:14:20 PM
Revit 2010 Yes/No in type catalog
Mon, Mar 29, 2010 at 9:14:02 AM
Page generation time: 4.9713
