Forums >> Revit Building >> Technical Support >> editing dimension text
Mon, Aug 29, 2005 at 12:45:07 PM | editing dimension text
RevitStructure1
Is there a way to edit the text after a dimension is placed?
Mon, Aug 29, 2005 at 2:21:12 PM | RE: editing dimension text
TomDorner
4.5 Stars: 25 Votes
You can add suffix/prefix but cannot edit the dimension. Best way is to get around this if required is to place text with opaque background over the dimension. We only do this for things like "see schedule" for door elevations and such. Other than that on the building model itself it is best to make it so the dimension reported is what it needs to be by making the building model correct. HTH Tom
Tue, Aug 30, 2005 at 12:11:43 AM | RE: editing dimension text
Audrie
Tom, I don't like the size and choice of text that comes automatically in the titleblock when I make a new sheet up. Is this customisable? Audrie
Tue, Aug 30, 2005 at 4:52:04 AM | RE: editing dimension text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
you can edit and create new styles to your hearts content. Of course your limited to the TTF installed on your computer...
Removing/editing single dimension in dimension string
Wed, Aug 26, 2009 at 7:12:02 AM
Wed, Jun 7, 2006 at 9:33:16 AM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Page generation time: 0.9715
