Forums >> Revit Building >> Technical Support >> Walls not cleaning up
Mon, Nov 16, 2009 at 10:48:02 AM | Walls not cleaning up
amore
Could somebody please help and let me know why my walls are not cleaning up properly?
Mon, Nov 16, 2009 at 11:01:25 AM | Walls not cleaning up
Why are these walls split apart - are they one wall or two?  If one wall, then do you have a wall that splits them and is hidden?
At the corner, pull one wall back then tell revit to  trim and extend them.  If that doesn't fix your problem, use the wall clean-up tool ...(Edit wall joins)
Mon, Nov 16, 2009 at 11:21:52 AM | Walls not cleaning up
JRMello
Looks to me like you have some demoed walls in an earlier phase that are affecting the new walls. Even though you can't see them demoed walls will affect walls in later phases forcing you to change the view's Phase Filter to Show All in order to see how the walls are interacting and clean them up the way you want so things look correct in the New Construction phase. HTH.
Cleaning Up Design Option Elements with Main Model Elements
Wed, Jun 17, 2015 at 1:38:27 PM
intersecting inner walls with slanting outer walls
Wed, Feb 27, 2013 at 7:51:10 AM
Joint between walls
Fri, Aug 30, 2013 at 1:37:29 PM
Cleaning up Chase Walls & Furring walls
Tue, Jun 14, 2005 at 3:49:07 PM
Wall cleanup issues
Wed, Apr 29, 2009 at 12:53:58 PM
Page generation time: 0.2999
