24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Adding trim to a door
3 Posts No Rating |
I have a sectional garage door that I need to add some trim to on the exterior. What is the best way to do it?
My advice is: open that Garage door family and create the "Trim" you need then save and load into project, IF you don't want that you can create that by "create in-place" in the category door.... BUT i use the first option...
3 Posts No Rating |
Thanks for the advice. Now for the even more stupid question. How would I create the trim? Its nothing more than a 6" wide X 1" deep trim around the outside of the door opening?
When you open that family you have the "Solid Sweep", create the path around the door then finish the path and create the profile with the shape you want, don't forget to add the "Material" parameter so in this way you can change the material in the project....
Wall Finishes Aligned to Door Trim |
Thu, Jan 21, 2016 at 4:08:48 PM
Door Trim Parameters |
Fri, Sep 11, 2009 at 12:52:57 AM
Edit/Add trim to Door Family |
Thu, Jan 14, 2016 at 10:02:29 AM
door trim stops short of floor |
Wed, Jul 24, 2013 at 3:24:32 PM
Specialty Door(s) - Help Needed! - Transom, Trim, etc. |
Mon, Jun 4, 2012 at 4:44:07 PM
