Forums >> Community >> The Studio >> Two Point Section Perspectives
Fri, Nov 13, 2009 at 4:25:24 PM | Two Point Section Perspectives
EnjoyRHCP
Hey all,
 I know you can create 1 point perspectives in revit but i'm looking to try a 2 point perspective, preferably
a section perspective.  If there's anyway to do this it would be greatly appreciated.
Fri, Nov 13, 2009 at 9:07:52 PM | Two Point Section Perspectives
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Turn on the section box in the perspective view.(in Element properties).
Sat, Nov 21, 2009 at 5:33:54 AM | Two Point Section Perspectives
tim123
4 Stars: 19 Votes
All perspectives are two point unless the camera is aimed directly at the disappearing point.
Edited on: Sat, Nov 21, 2009 at 5:34:32 AM
Wed, Jan 11, 2017 at 9:46:25 AM | Two Point Section Perspective in Revit
dinho2014
I'm still looking for ways to make two-point perspective sections in 2017 and still haven't figure it out. the solution by erland73 is an one point perspective because the view in that screenshot is a funstion of the camera not the section box, that solution is an approximation (shortcut/cheating) but thank you for the work around. Does any one know how? Any help is welcome.
Fri, Feb 24, 2017 at 8:19:15 AM | Two Point Section Perspectives
manuel7
camera views in revit by default are two point perspective... (actually for one point perspective view you need to align camera view with section box and use the same eye/target elevation)
Maybe you are looking for a simmetrical two points perspective? but that depends where you put your camera view.
Also you can increase focal length...
Edited on: Fri, Feb 24, 2017 at 8:20:29 AM
Perspectives printing all grayed out!!!
Tue, Mar 18, 2014 at 2:42:54 PM
One point perspective section
Thu, Jun 21, 2007 at 8:17:52 PM
Distorted Perspectives
Sun, Dec 31, 2017 at 5:07:34 PM
Perspectives not printing properly
Sun, Jan 22, 2006 at 10:22:48 PM
level elevation doesn't match elev point in topo / site plan
Wed, Dec 18, 2013 at 4:05:00 AM
13
Page generation time: 0.3621
