Forums >> Revit Building >> Technical Support >> I want to lock a line based family to a ref line
Fri, Nov 13, 2009 at 1:56:39 PM | I want to lock a line based family to a ref line
tovnicek
I am working on a parametric sunshade family. I have the outrigger and upper bracket working fine.  I have a reference line from the upper bracket to the outrigger flexing just great.  I have a clevis and rod assembly family that is line based, and it works fine as well.  I want to lock the clevis assembly to the reference line so that when the outrigger length changes, the clevis will adjust for length and angle as well (just like the refernce line does).  Please help
Mon, Nov 16, 2009 at 3:08:14 PM | I want to lock a line based family to a ref line
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Try using "align" and when you align somethign it will give you the option to lock it.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Mon, Nov 16, 2009 at 3:29:58 PM | I want to lock a line based family to a ref line
tovnicek
I just tried that and it says I'm over constrained.  I'm uploading so you know what I mean
Is it possible to make a line-based family wall based?
Wed, Jan 5, 2011 at 1:00:21 PM
3D line based hosted family template or solution
Sat, May 2, 2009 at 1:46:17 PM
Nested Family won't lock to 2 ref planes/lines
Fri, Jan 17, 2014 at 10:09:19 AM
Line based generic model family- RAC2008
Wed, Apr 22, 2009 at 12:00:15 PM
Family Typical Model based on line
Mon, Dec 22, 2008 at 7:55:47 AM
Page generation time: 3.1954
