9 Users Online (7 Members):
Forums >> Revit Structure >> Technical Support >> slab schedule
45 Posts No Rating |
hi, i am using revit structucture and am newbie from this new software how can i put the thickness of the slab to slab schedule? unlike column, beam and footing schedule, you can use edit family to share their demension properties to make them appear in the schedule but in slab i cannot do that, how can i make my slab thickness appear in my slab schedule? please help me thanks
"Pleasure in the job puts perfection in the work"
- Aristotle |
please help me, any suggestion on how to put the slab thickness to schedule? thanks,
- Aristotle |
1 Posts No Rating |
Just add the Default thickness parameter for the slab into your schedule
thank you for the response but there is a problem, you cannot make the "default Thickness" shared. you will end up adding additional parameter and will name it as "default thickness" but its value is not attached to its real thickness. its funny but i was able to answer this question after month of using revit (my company is still using autocad and if we are using revit, we're only using it for concept or preliminary design). there come a time that i need to produce schedule using revit and i just a minute ago i finally answered my own problem. since V=At where V is volume, A is area and t is thickness, since you cannot find any shared thicknesses in slab property but its volume and area is shared, you are forced to use formula in calculated property to have thickness that will appear in your schedule and also sincronized in its properties
- Aristotle |
You can't get a thickness from variable, compound system families like floors, walls, ceilings and roofs. But you can add a project parameter shared or not to these families. It just will not be parametric.
to schedule a void |
Sun, Oct 23, 2011 at 7:56:38 AM
Slab Egdes & multicategory schedules. |
Mon, May 16, 2011 at 2:04:35 AM
How to cut slab into segments? |
Fri, Nov 5, 2010 at 7:15:50 AM
Schedule concrete volume (including column, slab & beam) by workset |
Thu, Oct 28, 2010 at 8:04:52 AM
Adding parameters in a slab edge profile |
Mon, Aug 20, 2018 at 10:44:27 AM
